gm847 cam, what else do I need?
alright Im going with your simple gm847, and I know everyone will say go with a custom one but Its just my play car I dont need to get crazy so I am just curious what else do I need to get to put this cam in and get the car running? and what parts they suggest? thanks.
you'll definitely need some meaty valve springs...i would also suggest some 1.6 rr's,and some hardened push rods...they're are other things i would suggest to that are kinda needed but i dont know how much money you're working with
Valve springs, I recommed CC 918's. Also will need push rods, Ive heard of people using stock injectors with that cam but the gains arent as high. SO basically I would say:
*springs
*pushrods
*injectors
*RR's
*Tune
Im assuming that you already have headers, and a stall if you have an A4.
*springs
*pushrods
*injectors
*RR's
*Tune
I have pacesetter longtubes and a 3500 stall. would you guys suggest comp pro mag or crane golds 1.6? Do I need non self aligning? probably comp hi-tech pushrods 7.200? Should I use lt4 gears and timing chain? Im probably gonna go with a electric waterpump.
