anybody got a valvetrain?
if anybody is sellilng some kind of performance valvetrain or any of the components let me know. looking for anything from cam to springs, rockers, lifters, etc.are there other options in the $500ish or below range other than the hot cam kit?
The HOT kit springs are CHEAP and not really suitable for that cam even and that kit does not have lifters. So even the true cost of that kit is over $500 and it is some of the least expensive stuff you can buy for this motor.
Those springs also do not even fit the iron heads if you planned to use those.
think im just going to rebuild the bottom end and leave the heads and valve train alone for now. bore it 30 over and install new pistons, rings, bearings, rods, etc then save up for a nice h/c package
Originally Posted by 96capricemgr
Frankly most local "rebuilds" will just screwup a perfectly good stock shortblock.
Might consider a rebearing but that is about it unless there is specific other damage.
well im going to have to tear it down because the sludge buildup is ridiculous. i also want to check out the crank and bearings and i figure while its apart for $90 i can have it bored so why not.
Originally Posted by fergymoto
Plus the cost of getting it cooked/combo with new freeze plugs and cam bearings. Just save up and do it right.
what do you mean save up and do it right? its not right to rebuild the bottom end thats full of sludge? read my 2nd post. i said im going to save up for a h/c package and right now insatll new bearings, pistons, rings, rods, etc
Nevermind I misread your post. I was under the impression that you were just going to have the block bored and try to clean it yourself and reuse all your old freeze plugs and what not. I worked at a machine shop and you would be surprised by the amount of idiots that think they can let that stuff go then come back and say "ohh well I don't really know why my 20 year old freeze plug started leaking"
lol. no i was planning on a rebuild kit with freeze plugs, bearings, pistons, rings, oil pump, and other misc. things
