Any EGR delete guids?
Old 03-05-2007, 11:22 AM
ckyconan2003's Avatar
Default Any EGR delete guids?
I am planning on deleting EGR from my car since the headers im getting arnt EGR. Any guides to doing this, or possibly a list of everything needed to be taken off or deleted?
Old 03-05-2007, 12:41 PM
WhyHelloOfficer's Avatar
http://shbox.com/1/egr1.jpg
^^ That's basically all you'll need to delete to get rid of your EGR system. The AIR system is a whole other beast.. it is much more of a p.i.t.a. Get some EGR blockoff plates off ebay for ~$30 and you'll be good to go.
This is when I had my intake manifold off my car, it made it a lot easier to swap stuff out. It isn't impossible to do it with it still on the car though.
Old 03-05-2007, 01:16 PM
well my motor is completely apart, so whenever i'm putting it back together i i want parts on it i dont need.
Old 03-05-2007, 01:44 PM
So just pull the EGR Valve, Solenoid, and Gas feed pipe and get the blockoff plates and you'll be gravy
Old 03-05-2007, 04:45 PM
the_merv's Avatar
AIR is not that hard to do either.. take the crap off of the Manifolds, and cut off the Cross-over pipe. Then take out the Pump.
Old 03-05-2007, 06:26 PM
fastlt1's Avatar
What do you do with the line in pink?
Old 03-05-2007, 07:31 PM
the_merv's Avatar
Chuck it cause all that crap is coming off. That Vacumn on the Intake needs to be plugged, and then put on your cover plates.
Old 03-05-2007, 08:03 PM
camar0corey's Avatar
I can't wait to do my longtubes and get rid of all that junk, so long as I don't think about moving to CA.
Old 03-05-2007, 08:17 PM
so i guess i just get to throw away a lot of stuff lol....i may get the A/C pully delete too...
the_merv's Avatar
You can as long as you keep out of state plates..A friend of mine is out there.
Old 03-05-2007, 08:29 PM
fastlt1's Avatar
Is this right.
Old 03-05-2007, 08:35 PM
just ordered mine off ebay from UMI...NO idea what the third plate is for....
Old 03-05-2007, 08:54 PM
the_merv's Avatar
Third plate is for the Passenger side Header.
Ditch all that stuff and the Valve on the Back. Cap that one and bolt the plates in, that's it.
Old 03-05-2007, 08:59 PM
fastlt1's Avatar
Ditch EGR solenoid, EGR valve, EGR exhaust gas feed pipe, and cap off vaccum feed. Correct.
Old 03-06-2007, 02:39 PM
ltgun_anr's Avatar
will u lose any power if all this stuff is still in place but the gas line and vacuum to the solenoid arent connected to anything?
Old 03-06-2007, 03:51 PM
nah man. my motor is apart so thats why im deleting all this.
Old 03-06-2007, 04:03 PM
LT1~LS1's Avatar
I traced the egr gaskets and made my own block off plates.
Unless U like the pretty billet ones.
Its really easy and cleans everything up nicely!
Old 03-06-2007, 04:06 PM
already ordered em lol....
Old 03-06-2007, 06:18 PM
Captain Morgan's Avatar
anyone ever weld plates on?
Old 03-06-2007, 08:08 PM
transam5.7lt1's Avatar
Any major benefits from removing these pieces of emisions?
Quick Reply: Any EGR delete guids?
