Fog Lights Not Working
Well my fog lights just stopped working. I put new bulbs in last month. Checked the fuse and relay in the box under the hood and found nothing wrong with them. Changed them out just be sure and still nothing. The light illuminates on the switch itself so I ruled that out. What else could it be? Doubt very seriously that both new bulbs burned out at the same time, not impossible, but i doubt it. Any suggestions? Is there another fuse in the fuse box in the car. I saw nothing on it that pertained to fog lights and I firgured that the switch wouldn't light up if that was the problem.
umm if i remember right i had my high beams on the first time i had my T/A and i think only the top lights go bright but the fogs stay offf. try pulling back the turn single lever and playing with that....Dunno much but try that and make sure that the light switch is all the way to the right...
my bad, disregard my last reply, there should be a button right below the light switch, click on that. i know its obious but i have made that mistake the first time i owned my T/A.
wish I could help you, dropped in to see the resolve, mine are not working either, thinking about ditching the stockers and going with some pretty expensive replacements that are much better and the right size/shape.
Well, since you checked all the fuses and such the first step is done. Try checking the wires for breaks and such.
My idea is that the foglights automaticly go off when the highbeams are on. Laws require that you can not run accessories when running highbeams. There might be a short in the stick or surrounding areas.
I would check that out, too.
-bryan
-bryan
