key stuck in ignition
hello everyone, just recently purchased a 91 rs, the seller put the kep in and turned the steering wheel and pulled th key out with no problem.... the car has no motor and there was not power hooked up to the car when the seller showed me this. i hooked up power and put the key in the ignition, and not the key will not come out.... i am trying to put the motor in but there is no use to put in if i can not crank the motor.... so the bottom line is the key is stuck in the ignition can anyone help me please.....
Yeah - could be as simple as a button too....I don't know if GM was doing that goofy set-up in '91...I don't have anything of that vintage - All my stuff is several years on either side. My '86 T/A doesn't have anything - but my '93 Corvette does have a button.
