96t/a Whats The Biggist Tire I Can Fit In Wheel Wells
I Have A 96t/a And I Got My Stock Wheel But Want 2 Put Drag Radials And Want Wide *** Tire But Dont Want Any Problems With The Wheel Wells Stock 16"
I have seen a T/A with 335 on the back.
I did a search and I seen this pic these are 335 on a camaro
https://ls1tech.com/forums/wheels-tires/640718-will-335-s-fit-97-camaro.html
255/50/16 BFG g-Force T/A Drag Radial
http://www.bfgoodrichtires.com/specs...dial/1161.html
245/50/16 Nitto NT555R (Drag Radial)
http://nittotire.com/#index%2Etire%2Ent555r%2Esizes
255/50/16 Mickey Thompson ET Street (Drag) Radial
http://www.mickeythompsontires.com/s...ETStreetRadial
These are your only options for a 16" wheel. I have linked each Manufacturer's website so you can see what size options you have for a different sized wheel.
To go real big, 275+, you will either need to do a 15" drag wheel, or 17" or bigger diameter wheel. 16s don't offer much in the way of going with a wide tire.
Hope this helps!!
Hope this helps!!
