Edelbrock LT1 intake on ebay
Old 03-19-2007, 12:53 PM
Chaotic Firebird's Avatar
Default Edelbrock LT1 intake on ebay
Found this while browsing
http://cgi.ebay.com/ebaymotors/Edelb...em190092399534
Old 03-19-2007, 07:57 PM
Captainofiron's Avatar
nice find, man looking down the inlet ports there are alot of bumps and stuff to mess up the air flow
Old 03-19-2007, 08:50 PM
Blackbirdws6's Avatar
bought mine from that guy last week. Hoping for it to arrive this week and throw it on this saturday.
-Brian
Old 03-19-2007, 08:51 PM
nice blackbird, let us know how it goes and if you see anything that is an improvement
Old 03-19-2007, 08:54 PM
Mattybz28's Avatar
-Brian
Gonna be able to do a before/after dyno run?
Old 03-19-2007, 08:56 PM
fergymoto's Avatar
I will be surprised if there is any gain, just my opinion by the looks of it.
Old 03-19-2007, 09:04 PM
I had the car dyno'd just how it was 2 yrs ago with the only change of fixing two leaking header gaskets. I bought this intake because I have had the infamous rear intake manifold leaking issues since the car had 10k on the clock. It's been replaced twice and I still have the same problem. I'm figuring maybe its just the intake because if the dealer can't fix it and two other experienced mechanics haven't been able to...then maybe its the manifold. We have tried every single step of setting it down perfectly and not shifting it while following the recommended torque procedure.
I will report a gain regardless of it going up, down, or the same.
-brian
Old 03-19-2007, 10:16 PM
i420tom's Avatar
-brian
i thought that leak had something to do with heat from the egr system. Get the block off plates and say goodbye to the infamous intake leak.
just a suggestion, i guess i could be wrong.
Old 03-19-2007, 11:28 PM
buffman's Avatar
If I were you guys based on the pics I've seen of it, I would clean up the casting material on the inside of the intake around the ports. It looks horrible!
Old 03-20-2007, 02:27 AM
383LT1S10's Avatar
I'm pretty unimpressed with most of Edelbrocks stuff aside from the Vic, Super Vic and their E-Tec heads.
Old 03-20-2007, 07:29 AM
I put block off plates on the stock intake when I did the H/C. When I was having my clutch replaced, the guys noticed the oil leak from the rear of the intake and had me take a look at it. I will probably bust out the dremel a bit and do some cleanup, which is what I did when I got the edelbrock heads on the car. Things would have been different those couple years ago if my car wasn't my daily driver. I now have a spare vehicle so I wouldn't have been pressed for time in getting the H/C done.
I would have gone with an LE setup and called it a day but no reason why I couldn't pop these edelbrocks off and have them sent out for some lovin.
-Brian
Quick Reply: Edelbrock LT1 intake on ebay
