Water pump
Water pump
I was tinkering around with my stock WP today cleaning it up abit and all for my new motor. I plan on going with a mezier EWP so i took off the cover and noticed that the gear inside did not spin to freely I am just wondering that when i go with an EWP that if i have to remove that stock gear or if i have to still use it. and if so does it sound like I will need to buy a new stock WP just to run an EWP
Ok here you go chief, checked it out myself and it's a great writeup.
http://www.projecttransam.com/projects9.asp
for some other basics to start learning, getting ideas here is the main page.
http://www.projecttransam.com/projec...Type&Value=LT1
THx for the help 1 thing is what size freeze plug should i use for the shaft and bearing coming from the block. After i remove it
I don't know why the ewp manufacturers haven't included two freeze plugs instead of just one, but they really should. I bet if you called and asked they might just send you one. Or you can go to the hardware store and buy one for the timing cover. I used to large washers, a bolt and locking washer with some RTV for the timing cover and it works fine. There isn't a lot if any pressure against that spot, so it's not likely to leak. Just clearance everything properly for your timing chain.
Originally Posted by 383LT1S10
The pump should come with it.
