spark plug wires
Old 05-10-2007, 11:09 PM
1slowZinthe513's Avatar
Default spark plug wires
talking about my 96Z.. i have long tube headers on the car.. ever since i got long tube headers, they keep burning up my spark plug wires.. i just finished my engine build and i took the car straight to getting tunned and on the way there i burned one or more plug wires..
does anyone know of a FULL PROOF way of protecting the plug wires from those .. i have used many different types of sleeves and wraps.. and NOTHING has worked.. those headers keep burning them up
Old 05-10-2007, 11:14 PM
Kage's Avatar
Cool
Where are they getting burned by the boot?
Old 05-10-2007, 11:17 PM
Junk LT1's Avatar
custom length ran over the valve covers and down. no more burn wires.
Old 05-10-2007, 11:25 PM
yes.. right at the boot.. they burn before you can even route them a different way
Old 05-10-2007, 11:34 PM
the_merv's Avatar
Get the Factory Aluminum Covers for the Boots..
Kage's Avatar
Cool
Go with Thermo-Tec spark plug wire heat shield sleeves they reflect 90 percent of radiant heat up to 2000 degrees F.
Old 05-10-2007, 11:43 PM
where can i get each of these and how much??
Old 05-10-2007, 11:46 PM
the_merv's Avatar
Factory they are cheap.. go to any GM Dealership.
Old 05-10-2007, 11:52 PM
thanks alot ill check them out in the morning.. do they cover the entire boot?
Old 05-10-2007, 11:58 PM
Kage's Avatar
Cool
http://store.summitracing.com/partde...5&autoview=sku
Old 05-11-2007, 12:11 AM
80 for the one set and 68 for the other.. are those good prices
Old 05-11-2007, 12:40 AM
Kage's Avatar
Cool
Go with THE-14250.
Or go with 2 of these. Just cut 'em up yourself. Same ****, good stuff......
Old 05-11-2007, 12:42 AM
Kage's Avatar
Cool
What wires are you using?
Old 05-11-2007, 12:51 AM
the_merv's Avatar
I prefer the actual Boot Covers..
Old 05-11-2007, 01:04 AM
streetwarrior96's Avatar
I got Taylor's 8mm with Hooker LT... never burned up
Old 05-11-2007, 01:18 AM
i have gone through so many.. i used msd 8mm for a while.. this last pair i used Taylor's 8mm
Old 05-11-2007, 01:19 AM
Kage's Avatar
Cool
Have MSD's 8.5mm no prob here.
Old 05-11-2007, 01:41 AM
Young_Z28_Racer's Avatar
second that! my friend had the same problem and he did those and no more burnt spark plugs!
Old 05-11-2007, 01:43 AM
MSD 8.5mm's here also and no complants!!! and as for spark plugs go with NGK TR5's if your NA and if your on juice NGK TR6...
Old 05-11-2007, 01:18 PM
beast69camaro's Avatar
which long tubes are you running? at least on the hooker/jet-hots my vote goes to an over-the-valve cover set up....no burnt wires and it looks clean too. One of the best functional/aesthetic mods I've ever done.
