Want to get a cam what to get?
I want something slightly bigger than the lt1 hotcam but i dont need it to pull past 5800 and it has to pick up around 2000rpms atleast and can i get a link to it?
On the timing chain a new stock chain is usually fine on the used gears. Don't buy into all the stupidity you see here about needing a stronger timing chain, the stocker is not failure prone. I am aware of one single one breaking due to no outside cause. Seeing as I have been playin with this car for 7 years and am active on 4 boards that at least have BIG LT1 sections like this the fact I have only read about one means it is a very good piece.
This Lunati "Voodoo" cam is in that same range:
Advertised Duration IN/EX: 262/270
Duration @ .050 IN/EX: 211/219
Gross Valve Lift IN/EX: .507"/.515"
LSA / ICL: 112/106
Valve Lash IN/EX: Hyd/Hyd
RPM Range: 1600-5600
With 1.6 rockers, lift is .540/.548
http://www.holley.com/60120.asp
LSA / ICL: 112/106
