lt1 corvette fuel rail covers.
Old 06-08-2007, 08:11 PM
1996Formula's Avatar
Default lt1 corvette fuel rail covers.
will these work on my 96 formula with no modifications?
Old 06-08-2007, 08:30 PM
wrd1972's Avatar
No, they require hacking mainly due to the fuel line location.
Old 06-08-2007, 08:35 PM
enough to make them look like ****?
Old 06-08-2007, 09:56 PM
DroppedM6Z's Avatar
nope just alittle....
Old 06-08-2007, 10:42 PM
buffman's Avatar
Yeah no many mods needed to make em fit right. Mainly the fuel line. I believe the fuel line entry for the fuel rail is similar as the fcar. also notching the pass side for the fresh air vent hose. Heres the latest set I did for my car. I just bolted em on for pics the other day. I need to get the thing back together and start driving it
They took me some time to finish, because with an electrical charge they do something
Old 06-09-2007, 03:01 AM
thanks for the info!! those look bad *** lit up!!
Old 06-09-2007, 03:07 AM
Formula350's Avatar
EL Wired them up? Looks like the color of my EL Wire I have sitting next to me.
Old 06-09-2007, 10:57 PM
buffman's Avatar
Yeah the standard red EL wire. Very involved project, getting the epoxy to hold the wire down. I went with 2.3mm (slightly bigger than the wording) so it can withstand the engine heat better.
Old 06-09-2007, 11:52 PM
Irish350's Avatar
what if you replaced those lines with longer ones and rerouted them around the covers? would you need to cut em up still?
Old 06-10-2007, 12:02 AM
buffman's Avatar
you'd need the vette style regulator/fuel rail assembly that has the lines coming in from the opposite direction.
Quick Reply: lt1 corvette fuel rail covers.
