Valve spring swap
Valve spring swap
im planning on doing a camp swap here soon (iplan on running the cc306) and i was wondering if i could change the valve springs on the heads while they are still on the car. I really dont want to take the heads off but if i have to then i have to.
Also can use the stock retainers on the valve springs i plan on running? They are CCA-986-16 on summitracing.com or are there valve springs out there that can re-use the stock retainers?
yea changing them on the car is easy, they rent the tool at Autozone and you get buy a nicer tool from a "higher end" auto parts store e.g. NAPA, Pepboys, et cetera.
but ditto on the retainers and seats. Its a good idea to change them just in case they are worn, also they arent too much more.
Originally Posted by speed_demon24
Stay clear of the 918's. Patriot sells a cam kit that will work with the 306, the golds will work fine. $255 including springs, seats, seals, locks, and titanium retainers.
Originally Posted by Imnotfast
Why stay clear of the 918's?
https://ls1tech.com/forums/generation-iv-internal-engine/717173-what-hell-going-comp-918s.html
https://ls1tech.com/forums/generation-iii-internal-engine/728254-comp-cams-918-spring-broke.html
http://web.camaross.com/forums/showthread.php?t=513691
http://web.camaross.com/forums/showthread.php?t=525349
http://www.ls1gto.com/forums/showthread.php?t=164666
http://www.ls1gto.com/forums/showthread.php?t=159887
https://ls1tech.com/forums/showthread.php?t=717173
https://ls1tech.com/forums/showthread.php?t=728254
Thanks Good info.....Thought Comp was long past these problems
A couple of years ago I used these springs on a LQ9 (6.0) and just right after they were installed I was cruising at about 60 when one let go. Long story short I called Comp and they wanted the pieces back immediately, they paid for the repairs and all was well. So who knows what really was going on??
its was a few batches of the 918's they are past those problems, I made sure when I bought mine that they were a new batch, when you buy them they have a batch number and from this you can tell which are the faulty ones, Call Comp Cams they will verify this
I cant really afford the fancy pants 918's. Im doing a budget camp swap so i would like to use standard valve springs. Would the springs i picked out work with my stock heads with no machining or could someone recomend some that are not the 918's
I'm not going to be spinning the motor to 6800+ and i realize i wont get the full potiential of the cam. However later on when i port the heads ill put the 918's but for now ill keep it around 6-6200 rpm
