how much power do i have
and what do u think ill run
Factory Options:
94 Z-28 ...Black
Automatic
T-Tops, Black/Grey Cloth
Free Mods:
A.I.R. Pump Delete
Descreened Maf
ICM Space
Throttle-Body Bypass
Mods Completed:
APC Double Gauge Pod
BMR STB001 Shock Tower Brace (Silver)
BMR Lower Control Arm Relocation Brkts (Black)
BMR DTB001 Tubular Tunnel Brace (Red)
BMR MCA002 ChromeMoly "street" Adj Lower Control Arms (Red)
GlowShift 2 1/16 Tinted "Blue" Backlite Volt Meter
Reative 2 1/16 "Blue" Carbon Fiber Water Temp Gauge
k&n cold air intake
SLP Dual/Dual loud Mouth exhaust just put on 05/12/2007
Appearance:
Smoked / Diamond Cut, Tinted Clear Signal Bumper Lights with blue
strobs and blue bulbs
Wing's West Sport Wing
Lighting:Blue underbody lights solid tube
Safety:
1 Interior Mounted Fire Extinguisher
Stereo: one ppi a204 amp
2 12 in subs
home test of decables is 128.00
Some Current Stats:
For The People Of Stereo Intrest:
For The People Of Show Car Intrest :
08/20/05 A-Top 40 Pick- Of Show
06/25/06 A-Top 50 Pick- Of Show
List Of Mods..Forth Coming : headers cam and rockers
Factory Options:
94 Z-28 ...Black
Automatic
Free Mods:
A.I.R. Pump Delete
Descreened Maf
ICM Space
Mods Completed:
k&n cold air intake
Appearance:
Safety:
2 12 in subs
Some Current Stats:
Originally Posted by kyles2000z
not sure bc im not an LT1 guy, but why have you posted your appearance and stereo stuff....that has nothin to do with the power youre making or what youll run lol.
+1
maybe 15 HP at the flywheel. That would be an educated guess since all of your appearence and stereo mods are robbing you of all of your power. If you took all of that out you might see 275 at the wheels.
Depends on your altitude. Stock LT1s with good drivers here run 13.8-14 flat all day. Your LCAs,relos, and tq arm will surely help you launch, and I think a 13.7 would be possible at sea level if you can launch.
Buuuuttt, seeing as how you ran a 14.8(wtf?), I do not think you will break 14s without quite a bit more practice(or a tuneup!)
You ran a 14.8 with exhaust and intake and you want to know what you will run now? But I don't see anything new that you have done. Unless your talking about the free mods which are pointless. Did you add all that heavy crap after the 14.8? Because now I think your in the 15's
Stereos add weight, weight slows you down. I'm sticking with my stock 10speaker.
You really don't have much done in terms of mods to add power. Get a tune and that'll help some more, but with a driver mod I think you'll cut that 14.8 down a bunch.
