383 vibrations in motor HELP QUICK!!!!!!!!!!!
just built new 383 having a problem in the bottom end i think. used stock windage tray and stock oil pan on the windage tray rod bolts jst touched the tray didnt think it would be a problem car runs sik as hell 2nd gear burners into 3rd but like i said have a engine vibration if anybody ever had this problem please let me kno or what ya think could be wrong.THANKS
Originally Posted by 97LT1
sounds like a balance issue. Is it a M6? Flywheel 0 balanced?
LT1s from the factory are internally balanced in the front and externally balanced in the back. That means the stock flywheel/flexplate has a weight on it to balance the crank. Your 383 crank is most likely internally balanced. You need to get this fixed. Just take the flywheel to a machine shop and have it zero balanced.
Originally Posted by robby73z28
not sure what that means first time messn wit the lt1 its a 6 speed used everythng from old motor
