ABS Bypass
ABS Bypass
Okay i have heard this discussed but never in depth. It started out by my E-BRAKE light staying on all the time then all of a sudden the ABS INOP light now continuously flashes. I brought it in to my buddies shop and he said that one or more of the sensors have malfunctioned and that it would be pretty pricy to replace them. My question is how would i go about removing the ABS module and what parts whould i need?
I got rid of it, ended up with this. I haven't had a chance to test it yet, the car is still apart. I am using a 1989-1992 Camaro Proportioning Valve. I had to re-flare all the lines except for one, and put in a larger line for the back. Everything is where it should be.
The merv go it right,because he install a proprtion valve.
You absolutely need this valve to be able to keep decent rear braking force.Without it,your front wheel will block during emergency braking but the rear wil just continue to roll or slide and this could cause an accident.
With a adjustable proportion valve like a wilwood(50$) you will be able to adjust the rear brake so they will lock at the same time has the front one.
This is a pictures of the sjm abs delete and line lock kit.Fairly easy to do/install and adjust.
Originally Posted by litch2004
how much is that kit and where do i get it from. I know you put initials down...do i just type those in under a search?
http://www.sjmmanufacturing.com/ They are in the sponsor list.
Originally Posted by the_merv
That's what I was thinking..he wrote it a little confusing..
I used a Factory Valve that is setup for a car that is very similar, I think it will work, since I have upgraded Front & Rear Brakes compared to what that Proportioning Valve was originally part of.
I was just throwing you some flowers
Sorry im a french guy and my english is far from parfect
