AHH SMOKE START! i need help
**UPDATE w/ pics**AHH SMOKE START! i need help
So i have a 96 lt1.. a great day went crusin and such put her in the garage to wax her... at midnight go to start her ... i get nothing.. i try a few times nothing checked the voltage, its fine... I hold the ignition on start a lil longer and i got a hissing sound from somewhere by the passenger side.. and smoke started to rise through the dash.... I need some advice!
Thanks guys
Jaron
NEW***********************************
Well this morning i was off and had sunlight! i pulled of the glove box and smelled around... The circle deal as seen in the pictures smells like it was the thing burning.. i played with it, and guess what the car started right up!!!! can i ask what is this so i can buy a new one!
Well since you guys are the best heres some pics after 3 coats of zanos 2 and 5** im working on at least 2 more coats today!
Thanks guys
Jaron
I have a feeling the relay switch that actually sends power to the start burned up. it is located dead center of the dash, rigth next to the main ventilation. if you follow the center console up under the dash....keep going past the carpet, up along the actual metal of the fire wall you will see a box.
that would be more than likely what had burned up. if that gets hot, more than likely the wires were shorted as well. if you touch the rubber coating of the wire and it feels oily....you have major problems. more than liely you need a new dash harness. kinda of funny I have one. let me know if you have com to this same conclusion. you could have it for 50.00. it disconnects on the far right side of the dash.
bypass the systme, and see if the starter still works......... hope all goes well. check your connectors for some water as well. may have shorted wires down by the pcm in the engine bay while you were washing ti as well. .....just a possibility.
to get to that box do i have to take the dash apart? anyways i did a lil more poking around and found that the thick yellow wire under the steering column got extremely hot when trying to crank.... any ideas??
ORLY well the smell is coming somewhere over in that area..... and after wiggling wires its fine..... another ideas to check in this vicinity??? none of the wires are greasy either thank god!
