search not working - lt4 intake questions
can sombody link me to threads about lt4 intakes, edelbrock lt4 intakes vs lt1?
I have a 383 lt1, stock lt4 heads with a cam, headers, 3800 stall and 4.10's
still a stock lt1 intake though
got a 52mm tb and nice MAF - what should I do to get the most from the heads/cm/headers?
Port your heads first and foremost. You can cram all the air you can through the intake but if it gets stopped up at the heads you aren't really going to make justifiable gains vs. cost. Get the heads ported and the intake ported as well. With that alone you should see some very nice gains.
Now as far as the intake itself, I would personally start with the Edelbrock LT4 intake to match your heads as its much cheaper than a real LT4 intake.
oh - porting/swapping the heads may come later - I'll go about it then
not an option now as the car is together and fairly fresh
for now - just what intake will compliment my stock lt4 heads, 230/230@.050 ish cam, longtubes, 3800 stall and 4.10's?
is the LE ported lt1 a cost effective upgrade over stock lt1?
I have #30 injectors and adj regulator too
bought the car this way - trying to get it matched better up for now
thanks
thanks
Honestly, I would wait and upgrade it all at the same time and have a matched top end. Then you also won't be doing the same job more than once. But honestly if you already have LT4 heads then I would get a ported LT4 intake.
So - like my gut - your thinking toss an Edelbrock on it for now - won't hurt/might help. Then with more porting/aftermarket heads later, also port match the intake. Sound reasonable?
I've already concluded from reading that I will need to pull my intake and measure the port openings since so many gaskets are out there.
I've passed up one ported LT4 intake already because it has way too large oenings to match my stock heads. Need one I can use now - port to better heads later.
It may be over a year before I'm pulling the heads..
I wish I could find the dimensions of stock LT1, LT4 and Edlbrock LT4 openings...
Good Luck,
Daren
http://s85.photobucket.com/albums/k5...t=DCP_1455.jpg
GIZMO (Daren) -
Now that's a reply!
Any chance you know the port opening differences between stock LT1, LT4 heads - by dimension?
I ask so I'd be aware if a "ported" intake is for sale, the port size would exceed the size of my stock LT4 heads. Also as information about how much guys like AFR - that give their dimensions - are opening the heads up.
Do you think my cammed 383 with LT4 heads and LT1 intake will feel better with an LT4 intake swap?
Port opening the same - but said to be angled, distanced differently.
BTW - back a pic in your album clearly shows the extra material mentioned on the LT4 manifold for those reading this. Plus some nice parts and cars
Now that's a reply!
The port opening on an LT1 casting (10207643) is approx. 1 1/16" wide top, 1 1/8" wide bottom, and 2" tall. Note that there is a slight difference port to port on the same head. The LT4 opening is approx. 1 1/8" wide top to bottom and 2 1/8" tall.
Originally Posted by GIZMO
The port opening on an LT1 casting (10207643) is approx. 1 11/16" wide top, 1 1/8" wide bottom, and 2" tall. Note that there is a slight difference port to port on the same head. The LT4 opening is approx. 1 1/8" wide top to bottom and 2 1/8" tall.
1-1/8" wide, 2-1/8" tall LT4 port?
As for the rest - good data.
I guess I'll start with the Edelbrock intake and GM LT4 gaskets with a 52mm tb for now.
Should be improved over the LT1 and stock tb.
Then I can upgrade intake and heads later.
Thanks for all the help!
Geoff
I will have my LE Ported Edelbrock LT4 intake By Tuesday. Opened for a Monoblade with all the work he does on them, from his own words the stock Edelbrock is about as good as his Fully ported intake. So Good Things can come from a Ported Edelbrock.
Porting was $200, I'd say roughly 3 weeks depending on if he can get to it when you send it. Before and after will not be valid on my car, going from a Bolt-on LT1 to a VRE 383, LE3 AFR's, custom Grind cam, D1SC air-air setup, with a 4L80E tranny and all the little things in between, lol.
From what Lloyd told me the runners are longer than the factory castings, but there is less plenum volume. However with a Bigger TB like my monoblade you'll get it back. Also there is alot of material that can be taken out especially right behind the TB.
