Cam install parts???
hello,
im going to be getting a gm847 cam but im not quite sure what valvetrain parts to get...this is what i have on my list, but if there is something missing or wrong can you please tell me and i cant find a timing chain set for my 94 4mula i always find for a 93 or 95-97...
cc pro-mag RR 1.6 Non S/A 3/8 stud
cc 3/8 Rocker arm stud
cc 918 valve springs
cc valve spring 10 degree retainer
cc valve spring 10 degree locks
cc hardened push rods
Thank you,
Thank you,
You need to also get the beehive locators. You might as well do the valve seals while you're in there as well. There have been some pretty major issues with the comp 918 valve springs. You might be better off getting some PAC 1218 or 1518 beehives. Check out the group purchase section on www.camaroz28.com for more info.
The link below details all the parts, part numbers and prices for the cam install we did last year.
http://www.97transam.com/97ta-cam.php
Note it is VERY important to never skimp or cut corners when doing any work on your car.
http://www.97transam.com/gm847cam/install/IMGP2724.JPG
