FASTFATBOY goes to the track, times inside
Old 09-30-2007, 11:55 PM
FASTFATBOY's Avatar
Default FASTFATBOY goes to the track, times inside
Keep in mind I weighed the car, 3785 with driver.
The converter is not locking up at 95 MPH like it is supposed to.
I am still learning how to work the car and drive it.....
Best pass
60 ft 1.58
1/4 11.25
MPH 120.3
Not too bad for the first time.
When I fix the converter wiring issue, learn the car more and get some cooler air I can see 10.90's
David
Old 10-01-2007, 12:05 AM
In-Zane Moderator
ZONES89RS's Avatar
On motor??? Awsome times man, 11 second club for this man!!!
Old 10-01-2007, 12:09 AM
SincalT/A's Avatar
Thats haulin *** bud!Work out the bugs i wanna see some ten second time slips.
Old 10-01-2007, 12:23 AM
FASTFATBOY's Avatar
On motor, pump gas and drag radials!
David
Old 10-01-2007, 01:39 AM
Formula350's Avatar
With that MPH, shouldn't you be into the low 10s? That 60' is really good. Whats the reaction?
Old 10-01-2007, 07:47 AM
97blkz's Avatar
Really nice times David, what size stall are you running?
Old 10-01-2007, 07:57 AM
FASTFATBOY's Avatar
Its a TCS that flashes to 4300.
David
Old 10-01-2007, 09:08 AM
T/A KID's Avatar
120mph is typically only good for high 10's. I have a Buddy who's car with him in it weighs around 3,000 pounds (Cam only 6.0 liter) runs 10.95-10.98 at 120-121mph cutting 1.48 sixty's
Old 10-01-2007, 09:12 AM
RealQuick's Avatar
NIce #'s!
Old 10-01-2007, 10:21 AM
zigroid's Avatar
10s are yours!
Old 10-01-2007, 05:41 PM
flyinZ's Avatar
Put that car on a diet...10's with ease
Old 10-01-2007, 06:22 PM
hashtagBMW
Speed Density's Avatar
Looking good!
Tony.
Old 10-01-2007, 06:23 PM
FASTFATBOY's Avatar
I think it will run 10's like it is, I learn to drive it better, get the 60ft down and get the converter to lock up in the back 1/2 I am there.
David
Old 10-01-2007, 08:34 PM
smoknta's Avatar
Hope you have a strong double disc converter to handle WOT lockup.
Old 10-01-2007, 09:00 PM
FASTFATBOY's Avatar
I do, a TCS with a big kevlar lockup clutch, similar to a Grand National.....weird, before Ed's tune it worked, and it can manually be locked up with a tech 2. That tells me there is no wiring problem...right?
David
Old 10-01-2007, 09:20 PM
Hot94Z28's Avatar
Nice times man.
Old 10-01-2007, 10:05 PM
WYD-01's Avatar
you can lock it up with a tech 2 then wiring should be good
what tranny 60e or 80e
Old 10-02-2007, 08:51 PM
SS1156's Avatar
We need video, I want to hear that exhaust!!!
Old 10-02-2007, 09:47 PM
duff man's Avatar
Nice. Next time out try to get a video of that beast.
Quick Reply: FASTFATBOY goes to the track, times inside
