fuel filter
the one in your tank you leave alone until the pump goes... that is merely just a filter to block sediments from the tank from getting into the hard lines. it isnt really the same as the in line fuel filter... but if you are getting a new pump i believe it should come with it as an assembly, if not then i would get a new one while you have it all tore apart.
