Lt4
casting for intake is on either the pass or driver's side by the injector bosses last time I checked. If it was out of a 93 Vette and the fuel rail crossover was in the rear then it's definately not an LT4.
Castings off heads I think are under the valve covers.
The heads will have LT4 cast on them. Look in the valve cover through the oil filler cap. The block will still be 327 but about everything else will be different. Heck, even the bottom of the pistons says LT4.
You are correct. All M6 vettes in 96 were LT4. All autos were LT1.
