lt1 swap
lt1 swap
I recently bought a wrecked 1994 camaro z/28, im going to swap the lt1 into my 1985 iroc, i was wondering what type of headers i will need to use, and also while the enigine is out what is my best bang for the buck without using nitrious?
thanks
thanks
Use headers that are designed for the 3rd gen. They will fit your chassis and bolt right up to the LT1.
The 3rd gen is a couple hundred pounds lighter than a 4th gen, so it should be fairly easy to make a strong running car. Decide exactly what you want out of the car and how you are going to use it, then do lots of research. There is tons of good info on this site, but you will have to sift through piles of garbage to pick up the good stuff.
Maybe someone else will chime in, but at this point I stand by my original post. There is nothing special about the way a LT1 header bolts up. Reverse cooling has nothing at all to do with the header. How in the world do you think people use Gen 1 SBC truck headers for budget LT1 turbo builds. It's because the headers will bolt right up.
I've seen quite a few people use the 3rd gen style headers and they work fine. But if it makes you feel a little better if you can find a set of LT1 headers that will fit in the car...I'd go for it. Just my .02
You can use the D-port headders or go 1-3/4. Head over to www.thirdgen.org there have been a bunch of LT1 swaps in a third gen you will find out everything you need to know.
