How much are ya'll spraying on stock internals?
I had a Zex kit and was spraying 125 (107HP at the wheels) and i sent atleast 15 bottles threw it in 3 months and mine ran just fine yet but i had to sell the N2O for extra money for school
150 many times, 200 hp for my fastees et, tried 225 but had problems with tranny and possibly the stall. I did not pick up any more with the 225 shot.
150 safely but you can push it if you want to. If going over a 150 I would go two stages or progessive to break up the torque spike. But it can be done. You just have to have the tune dead on, use the right plugs/gap, pull the right amount of timing. If you make a mistake it will be time for a rebuild.
sprayed 13 bottles on 150 shot over the summer, have gone through 3 bottles on 200 shot, running a TNT F2 plate kit dual nozzle, stock internal, stock manifolds, stock everything save for transmission/converter. stock tune, tr6 plugs gapped at .035, pulled plugs the other day and put them right back in, nothing showing that the motor is doing anything weird or dangerous.
On a 200 shot, would you guys recommend studding the block for the bearing caps? I thought I heard the stock crank might try to get wobbly at a 200 shot. I'm wondering as I'm planning on using the 200 jets for the shiny nitrous outlet plate sitting here. Going to be using a FJO. Rods/pistons are forged.
Interested also on Denny's question on the heads? Never gave much thought about if head design limits nitrous effectiveness.
I sprayed 250 out of the hole. The amount of timing to pull depends on the tune. If I have an aggresive N/A tune I will pull 6* for a 150 shot pulled 11.5 on the first pass spraying 250 then added a degree at a time . Made 4 passes spraying 250 that day and 4 passes before those at 200hp.
