Cleaning the Engine Bay?
I've Seen Alot Of Lt-1's That Have A Clean Engine Bay,i See Lots Of Stuff Are Removed But I Cant Seem To Know What Can Be Removed With Out Affecting The Car & Making A Better Room In There.
Remove the AIR pump, thats that black round electric motor by your air intake. Removing that cleans up the engine bay alot. You will not pass emissions after this and you will have to program this mod out of the pcm or ses light will be on. It will not affect performance. Also when you remove the pump, you have to remove the lines going to the exhaust manifolds and cap them off.
[QUOTE=kinglt-1;8013777]you will have to program this mod out of the pcm or ses light will be on. QUOTE]
on my 94 if you just left the relay in the fuse panel it thought it was still there but as soon as you take it out it gave you the ses light.
1 Post
i've seen guys relocate their batteries to the rear, and relocate their alternators down underneath. the PCM wires can be tucked underneath the fenderwell. certain pieces can get chromed for a cleaner look. i've also seen some relocate their fuel lines back behind the intake manifold. i've seen very few disassemble their brake lines from the M/C and route them a little neater. most of the vaccuum lines can also be tucked in a way that looks neat. a lot of it isn't "what you can remove" but "what you can reroute" instead.
pressure washer, MSD opti laughs at high pressure water
HA
seriously, I sprayed it right on, no issues, my coil arced a little, but no opti issues
EDIT: oops, just made the same mistake as BlackScreaminMachine
carry on
HA
carry on
friend of mines, cleaned up but nothing removed or re-routed;
My engine bay without removed ac (since removed), soon to have much more removed (goal is to be like the silver engine bay in its current state);
friend of mines engine bay (since had other things removed/re-routed)
as well as his battery, all the harness is re-routed, overflow tank is hidden, computer is hidden, junction box is hidden, heater box is gone
I re-routed some f my harness under the fender, re-routed the fuel lines, and since have deleted my abs unit and ac. My next tear down will go as far as the silver car but the silver car is in the process of removing even more from sight
