lt1 vs. lt4 knock module for juice use
Old 10-28-2007, 09:36 PM
SickboyT/A's Avatar
Default lt1 vs. lt4 knock module for juice use
which one is better for use with juice? i know the lt4 is less sensitive for rr's and headers, but places like summit/jegs say not for n2o use...what about the stock lt1 one for juice use? obviously i'm not spraying 24/7, so could the benefits outweigh the problems? i have a stock lt1 in there right now
Old 10-29-2007, 12:12 PM
Nads06111's Avatar
bump for good question
Old 10-29-2007, 01:16 PM
moserman's Avatar
yeah i love how on ebay it says its an LT1/LT4 knock module, when there is 2 different ones. how about some part numbers for the LT4?
Old 10-29-2007, 07:47 PM
SickboyT/A's Avatar
http://store.summitracing.com/partde...5&autoview=sku
Old 10-29-2007, 08:50 PM
GreenBlood's Avatar
damn, never thought about this question...bump for a solid answer...
Old 10-31-2007, 12:07 PM
chavez885's Avatar
Good question...anyone have some info?
Old 10-31-2007, 12:53 PM
Camz450's Avatar
from what I understand the LT1 mod pulls timing when it senses knock, LT4 mod has less sensativity and therefore doesn't pull timing, depending on what shot of juice you are using you need to have timing pulled to reduce the chance of detonation. Hope this helps.
Old 10-31-2007, 06:13 PM
SLawson86's Avatar
i would say performance would be lt4, safety... i would go with lt1 (in theory) I use an LT1 KM and i am on a 150 occasional 200hp shot
Old 10-31-2007, 08:57 PM
SickboyT/A's Avatar
i'm doing a digital 6 box this winter and that has a built in nitrous retard which i plan on taking advantage of...so the general consensus is lt4 km?
Old 11-05-2007, 08:28 PM
SickboyT/A's Avatar
ttt because i'm still curious
Old 11-05-2007, 10:04 PM
LT1
LT1's Avatar
GM LT1 knock module part number is 16177700
GM LT4 knock module part number is 16214681
if your looking to get a LT4 km from a dealership have them look it up under the corvette LT4, dealerships dont list them under f-body LT4.
Old 11-06-2007, 12:08 AM
onephatZ28's Avatar
I would go with the LT4 knock module because if you're going to run nitrous and if you were to detonate because of low octane the LT1 knock module would pull timing before LT4 knock module. The LT4 knock module is a lot less sensitive. There is no difference between the sensors themselves though. So, to be on the safe side, you should probably go with the LT4 knock module.
I'm no expert, so you might want to get a second opinion on the nitrous section of the forums. To me though, it makes sense. Good luck with your car.
Quick Reply: lt1 vs. lt4 knock module for juice use
