How car runs with spun berings.
How would the car run if it had spun a bearing b/c the guy ran it for like 2 second and it ran god except it sounded a bit rough and it backfired a bit.
can you give me an example i really want ot get this car but if he has a spun baring then that means ill need a new engine and that seems a little over board for me since i dont have atruck to transport it.
**** so do you guys think i should get the camaro? i really don't losse intrist in things and when im down to work on them i do until im done. Thanks
You have two types of bearings, rod and main. The rod bearing will knock like crazy, so it must be the main bearing(s).
As mentioned before, it will require pulling the engine, then the crank. Depending on the amount of damage done, you may get by with turning the crank and getting oversized main(s). Worst case, of course, is replacing the crankshaft.
you can also get a "refurbished" crank from o'reilly's. its just a stock crank thats been turned and polished by a division of federal mogul. it also comes with the rod and main bearings that match how its been turned.
thats what i did for my new motor and everything plastigauged out perfect. if you want i can get you the right part number tomorrow. they run like 160 i think if you don't have an account.
