LT1 swap help!
LT1 swap help!
96' LT1 from an Impala SS going into a 78' Malibu. My trans is a 200-4r. I've had the wiring harness modified for the swap by lt1350.com and I am not understanding the wiring diagram and these guys suck at customer support. Anyway, my issue lies in the tcc wire and the pnp wire. My 200-4r is already prewired with a converter lockup harness. I'm just trying to figure out how do I get a ground signal to the pnp wire when in park or neutral, and how to get 12volts to the tcc wire when the brake is not depressed. Yes, these are the only instructions I received with my newly modified $300.00 harness. Any sound advice would be greatly appreciated.
To get the 12v source to the tcc take test light to test the wires going into the brake light switch near the pedal find which one lights up when brake is not being pushed and goes off when you push it
Those guys at LT1350.com are abunch of jackasses I had a graft harness done by them not only did it not work properly the first time the second time i sent it back for them to check it out and do some work(with me paying) on it. They sent it back still and it still didnt even function properly and they pretty much said that it had to be something else and the harness was fine. Bought a speartech harness and all problems solved.
Actually I take that back. I had problems with my relays not working right and they kept falling apart. And my tune is pig rich and my rev limiter is set way too low. Just thought about all that. lol So maybe I did have some problems.
