look at this pic of my cam timing
Old 11-07-2007, 05:30 PM
powers84's Avatar
Default look at this pic of my cam timing
does it look right because everything seems to be a pain in the ***. i have other threads on this but i cant figure out why my engine is doing this to me. i think im going insane.
powers84's Avatar
here it is
Old 11-07-2007, 05:39 PM
Puck's Avatar
In a word? Yes. That is the #6 TDC point, dot to dot and 3 o'clock. Its been covered quite a few times.
Courtesy of shoebox. Text link to save his bandwidth - 2.1mb gif.
http://shbox.com/1/cam_timing_ani.gif
Old 11-07-2007, 05:48 PM
Burning Rubber's Avatar
I agree when number 1 is TDC both dots should be at the top
Old 11-07-2007, 08:08 PM
powers84's Avatar
ok so if the number 1 piston is top dead center righ tnow then im wrong because it is diffently tdc right now....
Old 11-07-2007, 08:29 PM
fordeater's Avatar
it is still installed corectly your just at #6 TDC rotate it and youll be at #1, the only problem youll have if you thought that was #1 would be valve adjustment, the opti will only go together one way.
this also confused me for a very long time because I was so used to the regular SBC, I put my whole motor together thinking that was #1 TDC and had problem adujusting the rockers because I was so confused.
Old 11-08-2007, 11:10 AM
powers84's Avatar
ok thanks and i was jusst told my cam pins not long enough, ?..............
its should be .540,
Old 11-08-2007, 11:41 AM
Scrapin'4.8's Avatar
its should be .540,
yeah was gettin ready to say that. u woulda really been confused later if u hadn't realized that.
Old 11-08-2007, 12:17 PM
powers84's Avatar
is there any way to fix this without taking the cam out , i was told to heat it up and pull the pin out does this work.
Quick Reply: look at this pic of my cam timing
