lt1 sensor list
lt1 sensor list
i am ordering all new sensors and electrical for my new motor i am building. does anyone know a website that tells all parts that are on a factory lt1. like as in oxygen sensors, knock sensor, temp sensors, etc. you get what i mean?. i just need to know the complete list of sensors and everything electrical for one becuase i am starting fresh. just tired of dealing with old **** that could possibly fail.
accel optispark
plug wires 8.5 mm. universal custom fit
plugs
ignition coil
ignition coil module
fuel pressure regulator
map sensor
MAF sensor
throttle position sensor
intake air temperature sensor
idle air control sensor
oil pressure sensor
knock sensor
downstream o2 sensors
2- coolant temperature sensors
radiator coolant level sensor
oil level sensor
thats what i have thought of so far. anything to add let me know. please. ordering next week
plugs
ignition coil
map sensor
MAF sensor
oil pressure sensor
knock sensor
oil level sensor
I would replace all O2's if you got the $$$, what motor, OBD1 or 2? how about the knock modual with an LT-4? other than that I am at a loss, it sounds like you have it covered.
accel optispark
plugs
ignition coil
map sensor
MAF sensor
oil pressure sensor
knock sensor
oil level sensor
plugs
ignition coil
map sensor
MAF sensor
oil pressure sensor
knock sensor
oil level sensor
