Torque spec for ARP rod bolts
Old 11-19-2007, 06:31 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Question Torque spec for ARP rod bolts
Hey guys.
I just spent 5 hours refreshening my Forged 383 short block, which btw will be up sale soon.
I got everything else completed. I put the rod caps on and lightly snugged them, but I was using my LT1 rebuild book which gives factory torque specs. like 25 ft lbs and then 55 deg. Which is for torque to yield....
So anyways whats the torque spec for the rod bolts. if it helps (not that it should matter) its a ARP rod bolt, Eagle H beam rods on a 4340 Chromeonly steel crank. My original build sheet didnt include torque specs.
Thanks!
Any questions on the motor (serious buyer inquire only pls), PM me.
Old 11-19-2007, 06:37 AM
thecorrectformula's Avatar
You should be able to give ARP a call and they should be able to tell you.
Old 11-19-2007, 07:00 AM
Internet Mechanic
Yea I may do that, its just so busy at work, often I cant get a chance to call, sad eh lol.
thanks for the suggestion
Old 11-19-2007, 08:43 AM
Internet Mechanic
I did find a FAQ on their site....
http://www.arp-bolts.com/Tech/TechTorque.html
I just need to look at the bolt, the part # i was 99.9999999% sure it was on the top of the bolt, as long as it matches then I think I am in biz, otherwise I gotta call.
Old 11-19-2007, 10:50 AM
Ari G's Avatar
Tq them 4times befor making your final tourqe
should be with your bolt package
Old 11-19-2007, 11:19 AM
Internet Mechanic
Umm thanks for the help, but this is a rebuild of my motor that was made by Nu-tek Motorsports in 2003, no longer in biz so I dont have the original packaging.
Old 11-19-2007, 05:01 PM
FASTFATBOY's Avatar
This should help
Subject: Eagle H Beam Connecting Rod Torque Specs
Torque Specs:
7/16" ARP 8740 Rods Bolts - 7/16" Bolt Head - 63 ft. pounds or .0059" - .0063" Bolt Stretch
7/16" ARP 2000 Rods Bolts - 7/16" Bolt Head - 75 ft. pounds or .0064" - .0068" Bolt Stretch
7/16" ARP L-19 Rods Bolts - 1/2" Bolt Head - 79 ft. pounds or .0073" - .0077" Bolt Stretch
3/8" ARP 2000 Rods Bolts - 7/16" Bolt Head - 43 ft. pounds or .0055" - .0059" Bolt Stretch
5/16"" ARP 2000 Rods Bolts - 3/8" Bolt Head - 28 ft. pounds or .0048" - .0052" Bolt Stretch
D
Old 11-19-2007, 06:19 PM
Internet Mechanic
thanks man, its def a 7/16 head, i wont be able to look at it until tommorrow but def thanks for the info.
Old 11-19-2007, 08:17 PM
Internet Mechanic
I checked the bolts they say.
ARP Eagle 8740 1.6's so I found my spec, thanks!!
Quick Reply: Torque spec for ARP rod bolts
