LongTube Install questions
Old 12-02-2007, 02:57 PM
kahunaking's Avatar
Default LongTube Install questions
So Im getting some ceramic coated Pacetter LT's and Im wondering what I can do about a cat and connecting to my stock exhaust. No place has any pictures of the Y pipe. I dont want to get everything and figure out that my new hooker catback wont connect to anything. Does the pacestter Y pipe allow me to cut and weld in a magnaflow cat or similar? Are there any flanges to connect my catback to?
Old 12-02-2007, 03:24 PM
217zenki's Avatar
Long tubes are not going to connect to your stock exhaust.. Unless u do some cutting and welding..
Old 12-02-2007, 03:26 PM
matt94z's Avatar
Why do you want to keep a cat?
Old 12-02-2007, 04:12 PM
Ralls's Avatar
I have a picture in here where I put my cats: https://ls1tech.com/forums/lt1-lt4-modifications/823103-exhaust-advice.html
Old 12-02-2007, 04:24 PM
kahunaking's Avatar
I want to keep a cat because I want to pass emissions. We dont have a visual but a cat will definatly help out in passing the sniffer test.
Old 12-03-2007, 10:00 AM
Mattsz28's Avatar
Personally, ditch the cats. A case of beer with most mechanics goes a LONG way.
Old 12-03-2007, 10:13 AM
Unertl42's Avatar
agreed
Old 12-03-2007, 02:14 PM
bricez28's Avatar
lol i bought my car without a cat, make friends with a mechanic.....
Old 12-03-2007, 02:59 PM
CamaroRacing12's Avatar
+3 on buddying up with a mechanic
Old 12-03-2007, 04:31 PM
kahunaking's Avatar
Anyone know about airzonas laws? I thought you needed to have the emissions testing done at the place by the DMV. If you can get emissions done at another place with the certificate i would definatly throw these on there and call it good.
Old 12-03-2007, 07:53 PM
kahunaking's Avatar
Anyone also know where I can find an install write up?
Old 12-04-2007, 06:20 AM
DarkKnightTA's Avatar
LT headers are a pain in the *** to put in, best bet take everything off around them and be paitient. Its going to take some time, but when its done it is all worth it. I recommend some locking header bolts, eliminate a problem before it begins. Just my .02
Old 12-04-2007, 12:22 PM
chavez885's Avatar
what kind of long tubes do you have? Emissions or race style?
Old 12-04-2007, 06:09 PM
kahunaking's Avatar
Race style. Ive also got new metal gaskets, Locking bolts, Spark plug wire sheaths, new wires.
Old 12-04-2007, 07:04 PM
chavez885's Avatar
go to www.lt1howto.com and click on FLP header install, that should give you a general outline...im assuming you're getting rid of the EGR and AIR system and pluggin the holes. Thats the hardest part for me. Couple things i learned during my recent install was.
First thing is the driver side header isn't going in without removing the shift linkage. Also, the passenger side isn't going in without removing the starter and oil dipstick,goes in easy from the bottom after that but you'll have to jack the car up pretty high to slide it in there. I did this with jackstands and a 3 ton race jack. If you have questions ask,i have it all fresh in my head unfortunately...lol
Old 12-04-2007, 10:49 PM
kahunaking's Avatar
Since I have the race headers I need the EGR and AIR blockoff kit? And will I need to get a chip (1993) to disable them so that I dont get a SES?
Old 12-05-2007, 08:13 AM
Bad_tx_Z28's Avatar
thats right...but insted of getting a pcm chip...send you pcm off to madz28 of pcmforless...and have it tuned for the LT headers and no egr and air...alot easier.
Old 12-05-2007, 09:36 AM
blk97z28's Avatar
OP go here to view my whole long tube header install process.https://ls1tech.com/forums/lt1-lt4-modifications/783145-my-new-exhaust-dyno-numbers.html
Quick Reply: LongTube Install questions
