94-96 LT1 manifold Tech question ? PICS?
I am wondering why GM cut the bolt hole like this on the intake bolt slot on the top of this picture? My 94(maybe actually a 95-97?) manifold has the same thing, and I have no intake leaks etc. I do use thread sealant on all intake bolts. But just curious as to why GM cut the hole like this, if they did?
Who knows, as long as it is factory.
The reason it is there is for easy assembly. It is used as a guide. Insert bolt and start, slide intake into place. This helps in assembly and stops some of the movement so the front and rear seal better with less movement. I actually use 2 short studs when putting on my intake to just drop it in place. I have a 94 and unslotted intake.
