dual spring vs beehive
Old 12-14-2007, 07:45 AM
JoeliusZ28's Avatar
Default dual spring vs beehive
Im putting together a parts list for my cc503 swap and im second guessing my spring choice (PAC 1218/1518).
Ive helped a few of my LS1 buddies do cam swaps and they have all used dual springs instead of the beehives im looking at. All of their cars dont seem to mind 6800 rpm one bit.
Is there a benefit to dual springs? I want a SOLID valvetrain, im not cheaping on stuff. I want a valvetrain than can take 7k rpms, even though i dont plan to spin my stock bottom end that high. I want every bit of reliability and power i can get. That being said ive read that beehives rev better because of their light weight and spring dynamics. opinions?
Old 12-14-2007, 09:08 AM
Schweet97Z's Avatar
well ill get this out of the way and say EVERYTHING mechanical is prone to failure, which im sure you know. I would personally run the Crane 10308-1 springs with your setup, as im running the same springs w/ my 847 cam and take it to 6800 rpms no problem.
Old 12-14-2007, 09:46 AM
WhyHelloOfficer's Avatar
The beehive design itself wasn't the issue with the Comp 918s breaking. It was a manufacturing issue with Comp switching suppliers. When the 918 was the 'go-to' spring for any cam up to .600" lift -- it was when PAC manufactured them.
The PAC beehive springs are a quality spring. People have been using the Comp 10308s because they're a less expensive alternative to the PAC Spring.
Old 12-14-2007, 09:51 AM
JoeliusZ28's Avatar
yea ive done my homework on the 918s and PACs, if i go with a beehive (looks like im going to at this point) itll definitely be a PAC.
Old 12-14-2007, 11:07 AM
Vicious95Z28's Avatar
Ls1's also have a much lighter valve train which contributes to their rev range, go with the PAC springs and reduce you valvetrain mass!
Old 12-14-2007, 03:24 PM
Yeahdoug's Avatar
If you're a little worried (nothing wrong with 1218s though) step up to the PAC-1518. The nitriding really does make it a much better spring and it's worth the extra $$$. It basically makes a good spring great. Better fatigue life, less load loss. Easily the nicest beehive on the market with PSI's being a close second.
Old 12-15-2007, 03:50 AM
3pnt4maro's Avatar
I second the 10308's..I been running them for a while and they are wonderful..they dont mind the upper rpms at all
Old 12-15-2007, 12:49 PM
1989GTA's Avatar
IMHO the reason to run dual springs is if one of them breaks you will most likely not eat a valve. Now as was stated the beehive has less mass and better harmonics than the dual springs.
Beehives do not require the seat pressure or the over the nose pressure that a dual spring does. So less wear and tear on your valvetrain with beehives. IMHO with the quality beehive springs out there the chance of breaking a spring is pretty remote. Heck GM runs them on there performance motors now and they have waranty them.
Old 12-15-2007, 06:43 PM
92camaroguy's Avatar
I would go for the 10308's thats is what I'm going to use with my 503 swap. IIRC LE uses the 10308's on his LE1 heads and I would not call that "cheaping out" to use them.
Old 12-15-2007, 06:48 PM
JoeliusZ28's Avatar
what is a 10308 spring?
Im pretty much getting PAC springs no matter what, regardless of dual or beehive.
Old 12-15-2007, 07:16 PM
ABA383's Avatar
I'm going on my 13th year with a custom dual spring set from Lingenfelter...They are actually on sale now for $69/set! You still have to buy the retainers, though....I use titanium retainers also from LPE...They are will definitely handle the CC503 and are very durable...
Definitely worth a call...LPE got its reputaion for going fast and being extremely durable...
--Alan
Old 12-15-2007, 09:04 PM
fergymoto's Avatar
^I have a set of those springs, locks, and retainer out in the garage. I have been saving them
Quick Reply: dual spring vs beehive
