Valve Covers!
Valve Covers!
I am curious...I am looking to put some valve covers on my LT1 Camaro, something nice to match the theme I will be doing with it. Will any late model SB350 alve covers work for my LT1, or do they have to be SPECIFICALLY for LT1??
If you dont mind a bit of toying around you can modify some to fit.
Here's the Canton's on my setup. I still need to clearance the passenger side cover a little to clear the rocker arm. The Comp Pro-Mags have a pretty fat body so depending on which rockers you have you may not have to do anything. These still have the notch for the alternator also.
Heres mine, you can get um from SDPP for pretty cheap. Fits real nice and aluminum....
https://ls1tech.com/forums/lt1-lt4-modifications/821836-winter-time-blues-heres-some-pics.html
https://ls1tech.com/forums/showthread.php?t=821836
