Which Cam...
Which Cam...
OK so i'm building a 355 LT1 and i have a CC305 in my motor now.. The new motor is almost ready but i want more then the 305, which off the shelf cam do you think i should step up to... I was looking at the CC306, CC503 and GM847 but if you know some thing else let me know, and no i wont do a custom grind.. thanks
https://ls1tech.com/forums/lt1-lt4-modifications/836200-stock-head-cam-cam-swap-guide.html
First off is your bottom end stock? If so swapping from the cc305 to the cc503 isnt worth the swap and swapping to a cc306 or gm847 is overkill. I know you said no to a custom grind but it would be the best choice.
Well in that case if you dont care too much about the drivability I'd go cc306, gm847 and the like since you can spin up to 6700+ safely with your bottom end being built. I'd personally figure out if your gonna go turbo or nitrous and have a custom cam built to optimize the entire setup.
