Mother Of All Clutch Posts...plus a Mcleod clutch giveaway!!!
Old 01-15-2008, 02:39 AM
98lswonz28's Avatar
Exclamation Mother Of All Clutch Posts...plus a Mcleod clutch giveaway!!!
First thing is first, just toasted a fresh STOCK clutch running 12.60s. in 2 passes. Car had a Mcleod single that lasted about 10k with all street time, and some nitrous though it. 175shot, 550hp style.
So whats the best clutch for certain people. From what I can see so far, is that the Mcleod single is THE BEST street clutch regardless of hp up to 550hp, and the street twin is THE BEST clutch period.
main focus is COST vs PERFORMANCE vs DURABILITY
Here are the classes, fill in where you fit, give as much info as you want for your class including cost, 1/4mile time, and how long its lasted. I will start with mine in the 350+hp class.
NOTE: at 350+hp you will need something better than stock if you ever take your car to the track. PERIOD. EVEN ONCE.
300+hp street
300+hp street/strip
300+hp strip
350+hp street 386hp stock clutch held nittos fine.
350+hp street/strip 386hp Mcleod single with 10k slipped. stock got fried 1k
350+hp strip
400+hp street
400+hp street/strip
400+hp strip
450+hp street
450+hp street/strip
450+hp strip
500hp street
500hp street/strip
500hp strip
550+hp street
550+hp street/strip
550+hp strip
600hp+ we all know to go street twin or better.
CLUTCH GIVEAWAY
The winner of the most clutches used by one person, will win my Mcleod single autographed by me, thats toast + missing a spring. shipped to his door. if the thread makes 3+pages........
Old 01-15-2008, 02:40 AM
Revelation Z28's Avatar
will you autograph it?
Old 01-15-2008, 03:09 AM
Formula350's Avatar
Should've seen the clutch my friend's diesel chewed up. Sheered EVERY rivet off the spline part where it meets the sheet metal that has the clutch pieces. Was supposedly good up to like 800ft/lbs. At any rate it came out in 2 pieces heh So he took some short grade 8 bolts and nuts and bolted it back together, then welded the nuts on the bolt and ground it down. Then he smoked the transmission lol It's pretty sad too since it's just a 90 Cummins with a bigger turbo, fuel injection pump cranked up more and a K&N. It's not even the intercooled model >_>
Old 01-15-2008, 04:27 AM
98lswonz28's Avatar
giveaway clutch will now be autographed.
if you have a 6-speed or ever did... you must post, or your opti will crap, and you dont want that.
Old 01-15-2008, 04:46 AM
camar0corey's Avatar
Well I'm on my third clutch. The stocker came out at 125k or so. A Centerforce DF was installed, that lasted about 20-25k. Not very long for the money spent on that if you ask me. Now there is a Hays street/strip in there, probably going to be replaced with something else when the new engine goes in as I'm going to be spraying it.
So I'm interested in what people recommend running for 550+ street/strip, as I should make about 550ish rwhp on the bottle.
Old 01-15-2008, 06:25 AM
LT1MAN's Avatar
im running a madman stage 3 and i am happy with it so far. not too much chatter, and it was pretty well priced. i only have a few thousand on it so far but its holding up to the little bit of power im making.
Old 01-15-2008, 06:43 AM
96LT1355Z28's Avatar
I put in a CF Dual Friction in 2001. Has countless 13.60 passes on street tires w/ 300 rwhp. Recently made 4 mid 12 second passes on slicks without slipping. Has a total of about 45K street and track miles. Who knows how much longer it'll last!
Old 01-15-2008, 07:15 AM
blackz6sp's Avatar
I went through 1 stock, 2 slp's, and 1 mcleod single disc. Within 25,000 miles. 320rwhp, 12.60's, strip/street. I never actually toasted them, as soon as I felt them slip they were replaced.
Old 01-15-2008, 10:11 AM
brokenbird's Avatar
i ent threw a stocker at 110 then a center force when i found the gas only about 10k later and now my custom matalic is about to say good buy
Old 01-15-2008, 11:06 AM
96redcamaro's Avatar
killed the stock years ago. then I put a ram HD in, killed that in a couple of months. now I have a center force DF, been holding up pretty good for about a year and 1/2 now.
havent driven it with the new motor yet (long story). so this is back in the bolt on days.
300+hp street ~330 rwhp have driven the freakin crap out of it. and still holding.
300+hp street/strip
300+hp strip
350+hp street
350+hp street/strip
350+hp strip
400+hp street
400+hp street/strip
400+hp strip
450+hp street we'll see what happens with the new motor
450+hp street/strip
450+hp strip
500hp street
500hp street/strip
500hp strip
550+hp street
550+hp street/strip
550+hp strip
Old 01-15-2008, 11:20 AM
great421's Avatar
SPEC 3+ on my bolt-on plus LT4 Hot Cam - after 20K still going strong; no chatter now either - It finally broke in!
Old 01-15-2008, 01:47 PM
RealQuick's Avatar
SLP clutch assembly (stock LT1 disc with LT4 pressure plate). lasted ~5000 miles before it was removed and sold (wasnt slipping at all). the car made 383rwhp and ran drag radials on the street.
Old 01-15-2008, 01:53 PM
97LT1's Avatar
I thought the mcloeud twin disk is the only really true twin disk. (because of the pressure plate)
Old 01-15-2008, 02:36 PM
Hot94Z28's Avatar
Stock replacement clutch in it now. I took it to the track and slipped from the first run. Does fine on the street but I have a powergrip going in soon.
Old 01-15-2008, 02:45 PM
slick1851's Avatar
If your really going to be beating on it with a slick, your going to want a twin disk, or a heavy clutch to take the abuse
Old 01-15-2008, 05:50 PM
99.9percenter's Avatar
I SERIOUSLY smoked my stock clutch trying to do a 3rd gear burnout at the dragstrip 5 years ago. Still the same factory installed clutch from 1994. Still have it. 100's of passes since. Still hooks like new. 350 rwhp 1.7 60 foots.
Old 01-15-2008, 05:59 PM
daniel6718's Avatar
ive got a stocker i make around 430hp...no problems another friend had a stocker with a cam only motor making 358 spining it to 6800 rpm
another friend bolt ons plus 150 shot made arboud 450 and it lasted never had a problem 30k miles
Old 01-15-2008, 06:15 PM
98lswonz28's Avatar
blackz6sp has the lead at 4 clutches so far......
im eager to see what the 350-550+ strip only guys are using.
took mine out today and didnt slip in 5th or 6th but I can tell the clutch is very close to being done after 1200 miles and 2 passes.
be sure to put what class you are in.
Old 01-15-2008, 10:56 PM
randyss's Avatar
Taner where are you you have this covered. But I really don't think he wants you clutch as a prize. He has his own the one that came thru the bellhousing and floor just recently it was a Mecloud Street Twin that has seen it's share of abuse. LOL
Old 01-16-2008, 08:35 AM
DAVE00's Avatar
Wink
Check out what a little oil leak and clutch equals:
Centerforce Dual fric with the puckets sheared off and 4 of the nine pads missing on the flywheel side:
Attached Thumbnails Mother Of All Clutch Posts...plus a Mcleod clutch giveaway!!!-img023.jpg
Quick Reply: Mother Of All Clutch Posts...plus a Mcleod clutch giveaway!!!
