10 second with a stock 10 bolt and gears
Old 01-15-2008, 08:56 AM
th3brandon's Avatar
Default 10 second with a stock 10 bolt and gears
any one make a 10 second pass with a stock 10 bolt and gears in a lt1
Old 01-15-2008, 09:04 AM
will62085's Avatar
i know hunter02ss went 10.x at 140ish mph on a 10 bolt and 315 nitto's...dunno what was in the 10 bolt.
Old 01-15-2008, 09:12 AM
BOLO's Avatar
I still run stock 10 bolt w/4.10 gear and TA cover and make 10 second passes.
Old 01-15-2008, 09:52 AM
Formula350's Avatar
But do you spray out of the hole?
Old 01-15-2008, 10:02 AM
BOLO's Avatar
I'm still experimenting with the MSD window switch on rpm. The N2O run on my sig, switch was set at 4000 rpm. Going to try lower rpm next time when the track open up in spring.
And yes, I'm aware that it will shock the rear end even more so. But we all take the consequenses if we want faster times, right?
Old 01-15-2008, 10:04 AM
Formula350's Avatar
I let you all do the gambling and I just see what you can do and then dream
Old 01-15-2008, 10:08 AM
SpeedDensityZ's Avatar
My pops was hitting a Bone stock 10 bolt with a TA cover out of the hole with a 200 shot running 10.30's at 135. It is now in my car and I am pulling 1.6's out of the hole. She's whinning but, she's still working good.
Old 01-15-2008, 10:12 AM
BOLO's Avatar
"Don't think, feeeel,It is like a finger pointing away to the moon.....Don't concentrate on that finger or you will miss all that heavenly glory". Bruce Lee-Enter the Dragon.
Old 01-15-2008, 10:44 AM
DopdBrd's Avatar
I'm hoping my rear will hold up. I know lots of A4's that do it, but a M6 shocks the rear a lot more than a A4 does since the rear is not preloaded like the A4.
Old 01-15-2008, 08:39 PM
jakesz28's Avatar
I'm a auto here with a 3600vig and my 10 bolt gave out after one 1.48 sixty foot time. That was a 11.0 at 112 had to get out of it the car got loose down track. The next pass bang. I was leaving the line on a 200 shot.
Old 01-15-2008, 11:45 PM
donkey mule's Avatar
Start saving for a new rear end. The 10 bolt will eventually break - it is just a matter of time.
Old 01-15-2008, 11:57 PM
daniel6718's Avatar
ive gone low low 10's with a 1.50 60' stock 3.42 gears...i just keep breaking axles
Old 01-16-2008, 01:34 AM
skinnies's Avatar
I run 10.80's w/ 1.5x 60ft's on mine, my buddy runs 10.4 with a 1.4x 60ft's, my old camaro went 1.5x 60fts on the stock 10 bolt, and my buddies 6 speed lt1 goes wheels up on the street on his.
Old 01-16-2008, 07:18 AM
Davey J's Avatar
just fork out the 2k and and you wont have to worry about it for a long time
Old 01-17-2008, 11:03 PM
Z28&WS6's Avatar
time in sig is with the 10-bolt. all stock except for the 3.73 gears. of course this is with an auto and a 1.7 60ft
Old 01-18-2008, 05:27 AM
Davey J's Avatar
you must have let off on that run or ran out of rpm on the big end.Those numbers dont add up to a 10.1.More like a 10.90-11.0
Old 01-18-2008, 05:30 AM
skinnies's Avatar
10.1@128 1.7 60' and threw belt
Old 01-18-2008, 09:03 AM
T/ALT1's Avatar
I ran 10.17@133mph (175HP n2o) on the 10bolt with stock 3.42 gears in it back in 05 before I stepped up to an 8.8" rear. I still have that 10bolt sitting in my shop.
Old 01-18-2008, 09:29 AM
LT1SC95Z's Avatar
2k for my moser 12 bolt and gear, ready to install. well worth the money when you put on DR's and a stall.
Old 01-18-2008, 09:49 AM
street demon2k3's Avatar
A friend of mine ran 10.7@127mph with a 150 shot out of the hole. That 10-Bolt was toast after the run, but it took a lot of abuse before it went. The rear had 3.73's/TA cover and that's about it, I was shocked it lasted so long.
Quick Reply: 10 second with a stock 10 bolt and gears
