Stock Bottom End Dyno#s For LT1 N/A 93 Octane and on E85
Old 04-06-2008, 09:57 PM
LPE Z Convt's Avatar
Default Stock Bottom End Dyno#s For LT1 N/A 93 Octane and on E85
I dynoed my car Saturday @ Pro Dyno Tech in Crawfordsville, Indiana.. The car is an UNTOUCHED from the factory stock bottom end. I have LPE ported heads , Joe Overton cam and Eric Bradby did Intake porting and portmatched everything to the intake. The car also has all the supporting mods for this setup. The car has 63,000 miles on the odo. The car is also a 6-speed with a strange 12bolt. The last time i was @ pro Dyno Tech the car made N/A 416rwhp and 399rwtq but later discovered the car was running 110-120percent duty cycle on the 30# injectors.. I put 42# injectors in and retuned the car with great results.. The car made 442.1rwhp@6300rpm and 405rwtq@4900rpm. Then we switched to E85 and the car made 457.8rwhp@6100rpm and 421.0rwtq@4800rpm.. I am not sure what the dyno record is for a stock bottom end LT1 N/A is but i have to be close.. I will have track times soon.. The car increased across the board on the E85 not just in one certain area. To say the least i am happy..
Chris
Old 04-06-2008, 10:03 PM
StealthFormula's Avatar
impressive numbers nice job! could you give an approx. size of the cam? Looking forward to seeing some track times.
Old 04-06-2008, 10:07 PM
230s 240s on a 109 Lsa Lift is 574 In/ 544 exh The cam is great..
Old 04-06-2008, 10:25 PM
LS1 Eddie's Avatar
Sounds awsome. Those are some very solid numbers. E85 is great.
Old 04-06-2008, 10:41 PM
Formula350's Avatar
Full 100% E85 or a ratio of 93/E85?
My car didn't like running high % of E85. So I figure I could probably push 50:50, but if I do I play it safe and go 60:40. (Petrol/E85)
Old 04-06-2008, 10:45 PM
phirepower's Avatar
when is E85 gonna come to mass>? and what is involved with the ethanol conversion other than larger injectors
Old 04-06-2008, 11:34 PM
bigbadblack93z's Avatar
why the switch to e85? just for the sake of using it? if so thats cool. i'm wanting to do the same there are a few stations around here.
Old 04-07-2008, 12:08 AM
rasputin's Avatar
stop using E85 so the economy can get better. thanks.
Old 04-07-2008, 12:16 AM
Geneticallybroke's Avatar
How would that help the economy??
awesome #'s on a stock shortblock, nice
Old 04-07-2008, 12:48 AM
96silverram's Avatar
Great numbers !
Old 04-07-2008, 01:36 AM
CamaroRacing12's Avatar
yea sweet numbers and whats involved in switching to running E85?
Old 04-07-2008, 01:41 AM
B-Rad420's Avatar
Awesome results! Video? Brad
Old 04-07-2008, 02:09 AM
Formula350's Avatar
Because it puts pressure on our food supplies to make the E85. E85 isn't made from air after all
Old 04-07-2008, 04:11 AM
LT14LIFE JT's Avatar
Very impressive numbers, especially through a 12 bolt. The cam specs are unreal. I always thought that LT1s loved a high exhaust lift, but the dyno proved that theory wrong...LOL Time for some more R&D. Also, when is E85 coming to the east coast?
Old 04-07-2008, 04:57 AM
Formula350's Avatar
With the new "E85 is bad for the environment and the economy" vibe going around, either never or the far future.
APPARENTLY It's exhaust output isn't any better than fossil fuel, only thing is, is that it's a renewable resource. And 105oc that's cheap for us
I know there's a better list out there, but just goggle E85 Gas Stations and find the one that tells exactly where they are. This one does show some east coast stations
http://e85vehicles.com/e85-stations.htm
Old 04-07-2008, 06:28 AM
LS1 SPEED's Avatar
wow ! great #'s
Old 04-07-2008, 07:22 AM
Formula934's Avatar
The reason the car didnt like high amounts of E85 is because ethanol has a lower energy density that regular gasoline fuel. With that in mind i dont think ill be putting that in my tank... Ever.
Old 04-07-2008, 07:40 AM
LT1BRN's Avatar
Great numbers for H/C, care to list your supporting mods?
Old 04-07-2008, 08:05 AM
SpeedDensityZ's Avatar
Great numbers!!
Old 04-07-2008, 10:17 AM
Colin91Z's Avatar
Damn nice #s
By the way, where did you get a Joe O cam? I didn't think he was selling to the public anymore....
Quick Reply: Stock Bottom End Dyno#s For LT1 N/A 93 Octane and on E85
