Taking apart stock rear end... need some help
I had a loud knocking noise coming from my rear when i took turns in a parking lot... then i started hearing it all the time when i took corners. So then i knew something was up. I went to GM and got the posi additive, and I went to the ZONE and got some diff fluid. I then went home and took the diff cover off, and there was plenty of metal on the magnet, and i also found this in the metal pile...
sweet. so I check the gears... ring and pinion are obviously fine, the axle gears are a little beat... then I look up at the spider gears, and BLAM. teeth missing. lol. sweeet. Time to take apart the rear.
So I got the axles out, and I took off the carrier saddles or whatever you want to call them... and I cant seem to get the carrier out. Do i just spin the driveshaft and the carrier will pop out? or do i have to take the pinion out, or is there something im missing? Thanks for the help!
also, I counted the splines on my axle, and i counted 28... so is this the right gear setup, or did I count wrong? lol.
http://store.summitracing.com/partde...5&autoview=sku
haha. i was thinking about taking a belt and tying it around, then using a slide hammer or something. Also, will my panhard bar be in the way? or will there be room with ti in
open diff is wrong, but are you buying gears or a carrier? Open = not posi, but gears don't matter for that. At least not last time I checked. 2 and 3 series are different, but since you have an M6, you have a 3 series.
im just buying the spider gears... i just need to make sure im buying the right set. or should I just get them from GM? I get a discount because I work for my uncle, so i get his price
Well I assume yours looks like this?
http://tacreationsusa.com/images/Rears/dsc02597.jpg
I assume that even open-diff is the same spider gears.
This is what my new posi looks like (99-02 rears), so I have no spider gears so to speak (I'm sure they call something in there "spider gear" heh, pretty sure those vert ones are worm gears)
http://tacreationsusa.com/images/Gauges/dsc02809.jpg
If you call Summit, they are a pretty decent help to get what you need.
got the parts ordered from summit, will be in tomorrow i have to get carrier bearings too... they got some debris in them and gouged some of the bearings...
