LT4 Hotcam kit
https://ls1tech.com/forums/showthrea...ghlight=hotcam
I think the Hotcam kit is a pretty good deal but I think when I do it I will be using this to choose my cam. https://ls1tech.com/forums/lt1-lt4-modifications/836200-stock-head-cam-cam-swap-guide.html
If you plan to go bigger in the future(which if you are like most of us, you will) then the LT4 kit is not the best investment. It does include everything, but I would not use those springs on anything bigger than the LT4 hotcam. If you plan to go bigger, then I would stay away from the LT4 kit.
What r your plans for your car? Is it a daily driver, street strip, full drag car? What times are you shooting for? Theis simple little questions can help us and you make a decision if the hotcam kit would be best for your needs.
The springs in the kit are insufficient for the heavier LT1 valves, so add in the cost of replacing those at a minimum.
The rockers in the kit are limited to .550 lift and are 3/8" stud so like said if you plan on more power in the future you would be buing rockers over again too.
It works, makes OK power but it's popularity is bades not on results but on the fact it is sold as a kit at a reasonable price and from there most people who choose it are uneducated on the subject so they don't realize the springs are not good enough and the rockers are not up to much more than this setup.
from what i searched up and read and from reading the comments that you all wrote and reading the links that were posted up, the LT4 hotcam kit is not for me. This is a street strip car, i am wanting to run low 12.5s or faster on motor and 11.5s to 12.0s on spray.
I don't think the cam is that bad personally for a sleeper. Buddy of mine has it in his 96 LT-4, no anything other than a decent tune and muffler eliminators. It sounds bone stock after it's warmed up and ran 12.2 @ 117 with a really old set of slicks. That isn't to bad if that's what your looking for. Although that is on a LT-4 and not a LT-1.
Basically my opinion is that the only worthwhile part of that kit is the springs and those only for use with a stock cam and 1.6 rockers which would be smarter to go non-SA and something like ProMagnums not with those low lift limited SA aluminum rockers.
