big problems with my daily please help quick!!!!
my car feels like it is missing at idle it drops to like 500 from the stock 800 idle. then while your driving if you are barely on the gas like crusining it starts to feel like it is bogging as well but when you got wot or give it more gas it clears up and runs fine but when you let off again it will start to bog in the same condition. could this be a fuel filter issue car is a 6spd and has 110k on it. idk if it has been replaced. it throws no codes when this happens check engine light stays off.
Whatsup buddy how fast are you going when this happens and have you done anything to the motor recently, o and do you have a jack and jack stands
I agree with elliots94z, the same thing was happening to me about a week after I bought the car, and I got under the car and looked at wires and one was hanging off of the opti. So look under and make sure nothing is off that shouldn't be and let us know what you find out.
Ya man, now would be the best time to see if there is a wire problem, just look for an arch somewhere and see if you need new wires or if it is something else. My car was arching on the coil right behind the waterpump near the smog pump.
ok new thing happened i drove to kinkos and on my way back i was a mile from my house it missed bad and the check engine light flashed for a few seconds and then went off. y would that happen?
so this means its likely not the opti and it is just a sparking wire. im gonna check in a bit im writing a college paper as we speak lol im crossing my finger that it is only a plug wire.
