Where to tap AC pressure sensor for wideband?
Old 05-06-2008, 08:31 PM
JoeliusZ28's Avatar
Default Where to tap AC pressure sensor for wideband?
as the thread states? which wire, and can i leave the sensor connected to the AC system as long as i dont use it?
thanks
Old 05-06-2008, 10:00 PM
JoeliusZ28's Avatar
got it figured out... if anyone else is wondering for reference its the RED wire with the black stripe.
Old 06-08-2016, 11:46 AM
afterburner82's Avatar
Bringing this one to the front as I have a question on this myself:
Where did you/should you tap into this wire? Under the dash by the diagnostic port or somewhere in the engine bay? -> Missed any answers in my search
Trying to narrow my search for integrating the wideband data into Datamaster/EEHack.
Thanks, everyone!
Old 06-08-2016, 01:53 PM
Catmaigne's Avatar
Thanks, everyone!
The connector is pretty close to the pcm on the shock tower. Little 3 or 2 wire plug with yellow seal. Tap into the output and run wire back into the cabin through the rubber firewall grommet.
Remember to change the AC pressure thresholds in the tune. Otherwise the wideband output will start triggering your cooling fans.
Old 06-08-2016, 02:41 PM
ACE1252's Avatar
See post #42 here...
http://www.camaroz28.com/forums/comp...-770192/page2/
Ditto on what Catmaigne said(excellent suggestion). I didn't do that and the fans will cycle as the voltage changes with the wideband output.
Old 06-08-2016, 08:43 PM
waltsfastz's Avatar
Subscribing, I need to do this as well
Old 06-18-2016, 11:15 AM
One last question (might be stupid): How critical is it to match the wire gauge of the wideband since the blue and black wires need to be extends to the AC pressure sensor?
In other words: Would a different wire gauge size extension alter the data reading sent to the PCM for data logging?
Thanks!
Old 06-18-2016, 05:53 PM
moderate Z28's Avatar
what is this needed for? Was gonna get an AEM wideband soon.
Old 06-19-2016, 03:15 PM
Anyone???
Quick Reply: Where to tap AC pressure sensor for wideband?
