possible aftermarket cam
Easiest way is to measure the cam lobes. To determine lift you measure the largest (thickest) then the smallest. Subtract smallest from largest and the result is the cam lift.
Take cam lift, and multiply by 1.5 and you have valve lift...stock is .450"/.460" if greater it will be after market cam.
Like I said the stock cam is a great core I had a 224/224 and a 230/230 .570/.570" solid cams made so don't look at your stock cam as junk but as potential jewel in the rough.
I've never really understood cam regrinds and how they make them bigger. Could someone go into detail on it, or link to details? Do they lose duration or some such?
I know because given a free calculator and being told to read the help file you continued to post 'bugs' that the ~125 word help file explained.
So no I won't feed you anymore. Giving a man a fish will provide him a meal, teaching him to fish will feed him for a lifetime!
LEARN to fish use google and READ. Babies get spoon fed, if you want to be viewed as mature then start being self sufficient.
The information is available on line. No can summarize the information you seek in 2 sentences, and I seriously doubt you would read even 2 sentences.
I'm SOOO sorry I hurt your feelings by not reading that help button, but no reason to be an *** towards me over it. It's just a very very rare occasion I need to read the Help section on a computer program. It's either straight forward enough, or something I can figure out pretty easily.
As for reading, I guarantee I'd read more than 2 sentences, or 2 paragraphs, or 2 pages! Every thread I post in I read every reply before I make my own.
Maybe you should take your new found philosophy to the rest of the people here, like those TB threads that are coming out of the wood work, or maybe anyone else that's simply looking for info that can most likely be found from a google search. The reason we ask here, instead of maybe doing the research ourself, isn't because it's easier to just have someone tell you it but because it's better to get the information from a person who you can ask questions about what they said.
Hopefully next week you've stopped bleeding and calmed down a bit.
I don't need to act like an E Thug, but since you are ignorant, powerless and live with mommy it is obvious you do.
Good luck you need it
I knew you were special when you did NOT know the difference between reliability and liability when you wrote me repeatedly to burn proms for you.
You wrote
...I'm pretty broke now and live with parents, and still need to find out what the hell is all done to my motor (found out it's been worked on).
My reply was
"I am Control Engineer. Sorry I only program in person and then only for friends because of the liability...Good luck "
And your priceless reply
"heh Like I'd ever hold anyone reliable for help. What about at least just burning the file for me then?"
Mommys callng...so keep sucking her tit and leave this alone.
My reply was
My reply was
My reply was
You should maybe trim down the ego a bit, would make you look less full of yourself.
BYE
And sure, I'll admit I didn't read over quoted material from PMs.
Yes, goodbye.
First he says he reads EVERYTHING, then well I didn't see that, then well you can't expect me to read and understand what I post?
WTF? You are an IDIOT and I didn't need you to prove it--but thanks for the clarity!
The one thing I dont like about this forum is people will try to battle over anything. He had a simple question which could have been replied to in a respectful manner even telling him he needs to do the research. But alas thats the internet even the rude can reply without consequences
Reality suxs just tell some they ARE idiots...
