Installed a little cam, enjoy
jet hot longtubes and a y-pipe. no emissions, just your basic bolt ons. my pcm for the car is being tuned atm so i had to throw my stock 96 pcm in there for now. will run much better with a tuned pcm.
the lsa is 112. ive got stock heads, with comp pro mag nsa 1.6's and some old style pac 918 springs. gm guide plates, hardened pushrods. new seals and seats retainers and locks.
yep stock heads here. they still make more power than a stock cam. the heads stop making power after somthing like 6-6300 rpm. still worth it.
in order to get everything out of the cam, you need better heads, ported intake and larger throttle body. otherwise its not going to make over 400 hp if that. but thats fine for me. it puts a little more excitement into driving it again. almost like a new car.
heres what shes like with a madz28 tune
View Video on FQuick
the tune made a huge difference. the idle is higher now and helps with the low oil pressure. after doing the videos, i went ahead and put my bulelt muffler on. a lot quieter but still nasty
