My cars rpm is too high,please help!
I failed smog for the second time.Rpms are high,and the car is overheating, the car has a cat,but i dont know if its been hollowed,how do i check?rpms are high at 15 and 25mph and there appears to be no vacuum leaks,please help
the signature is your friend... well for overheating i would check the thermostat...
get familiar with shbox website. know IT and luv IT!
http://shbox.com/1/4th_gen_tech2.html#thermostat_change
i'm not tracking your rpm question???
re
Here is a pic of the report, as you can see in the
NO (PPM) section the max measurements are
MAX -------------------------- Measured
689 at 15mph --------------------------955
706 at 25mph ------------------------ 952
everything else passed ok but those measurements failed the car. Heres a picture
Ahhh, you meant PPMs not RPMs. That will confuse people.
Those test results are a little blurry and hard to read, but it looks like you failed for oxides of nitrogen. The EGR (exhaust gas recirculation) is the system used to reduce N.O. emissions, so that would be the first thing to check, even if there are no codes for it.
LOL..I read "RPM's too high" and I'm thinking "let off the gas pedal...it's the one on the right"....lol.
But Formula413 has it...Parts per Million (PPM). Big difference betweent those two. Good advice^^^
