What auto trans used in 93 Z28s?
i just got done dealing with this issue lol
did a v6 to v8 conversion using a 93 z28 parts car.
assumed it had a 4l60e in it but after i tore it apart to rebuilt it
turned out to be a 700r4.
some say all 93 have 700r4's and some say just early 93's do.
easy way to tell is if there is a cable on the throttle body linkage besides
the throttle cable and cruise control. should have 3 cables.
the third one goes the transmission on the passanger side.
if it has that then it deff. has a 700r4
From the speed density guys
Driveline The 93 used the 4L60 transmission which was controlled by a TV cable attached to the throttle body. The 94+ cars used the 4L60E which was electronically controlled, and had no TV cable provision. Because of this, the 93 had a slightly different throttle body than the 94+ cars.
Who else has the best first gear ratio..3.06, lighting up the tires in first is always fun...my transmission is great, and i like the tv cable adjustment instead of the electronic, less **** to break and to tune. The 93 transmission is technically called the 4L60 without the e, a couple of people told me that it is a 700R4 with a reverse valve body, that is why trying to find a core is very hard. It was used in the 92-93 vettes, and the 93 camaros.
