Exhaust Leak and BLM Question?
Guys,
Still chasing down my split blm issues and just wanted to ask a quick question. I recently replaced my header gaskets and retorqued all my header bolts and used stage 8 locking ones to make sure they don't go anywhere. My y-pipe collector gasets look fine but I might have a slight leak (not 100% sure) on the pass side. Question could a small leak in the collector gaskets cause a false lean? I would think not as they are past/down stream from the O2's is this correct. If not then I am going to check the pass side primary again and go over the entire header for holes. Thanks.
Depends how close they are to the 02s. I've read that even downstream leaks a certain length downstream can still trick the 02s. I was having a hell of a time with split BLMs with the stock PCM. Check your header gaskets again, I thought I didn't have any leaks and when i pulled the motor I saw some visible leaks I couldn't see from the engine bay or from below the car.
