How strong is the manual transmission in the G8 GXP's?
Old 10-25-2008, 07:58 AM
STF Veteran
99-LS1-SS's Avatar
Default How strong is the manual transmission in the G8 GXP's?
*EDIT* thanks prostockjohn!!!!
I'm getting a GXP as soon as they come out and I'm getting it with the manual transmission. How much power can they handle and what are their weak links? Thanks!
Old 10-25-2008, 03:41 PM
Top Secret's Avatar
If you're getting a manual transmission, would that not be a T56? I was under the impression that the 6L80E was the sequential shifting transmission (automatic).
Old 10-25-2008, 04:48 PM
STF Veteran
99-LS1-SS's Avatar
You are correct. I, apparently, hit the crack pipe one too many times before I posted this. I am referring to the manual transmission. I apologize for that.
Clearly my sig applies to me.
Old 10-25-2008, 05:33 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Title fixed.
Old 10-25-2008, 09:05 PM
thesource's Avatar
Actually it will probably be the TR6060 which is basically a T56 design unit .
Old 10-27-2008, 09:12 AM
STF Veteran
99-LS1-SS's Avatar
It will be the TR6060.
What are the weaknesses of this transmission? Thanks.
Old 10-27-2008, 10:38 AM
85MikeTPI's Avatar
The TR6060 is a very strong trans, basically all the lessons learned from the T56 are incorporated into the 6060, and thus it's factory rated at 600lb-ft. Steel fork, carbon fibre multi-cone synchros, one piece countershaft, thicker input/output shafts, etc.
But the same as with a built-T56, a bad driver or malfunctioning equipment (clutch/slave/etc.) can ruin one just as easy.
So far though (for me) parts and manuals have been hard to come by.
mike
Old 10-27-2008, 11:14 AM
thesource's Avatar
I haven't even torn into one yet . I'm sure they will have their problems but only time will tell .
Old 10-27-2008, 11:35 AM
OneBadLS's Avatar
i believe the new CTS-V will have this tranny as well.
