Cartek clutch?
Old 11-03-2008, 06:02 PM
INTENESS's Avatar
Default Cartek clutch?
I'm in starting to put my cartek clutch in,does anyone no which side the prssure plate goes it has the splines sticking out on one end the other side is flat which side goes to the flywheel?Trying to get most of this done tonight so any help would be great.
Old 11-03-2008, 06:41 PM
CARTEK Racing
WS6TransAm01's Avatar
I cant remember how mine was installed......
I would give Max a call in the AM 906.317.4496
Old 11-03-2008, 07:07 PM
INTENESS's Avatar
Yea will give them a call tomm,soon as I got motviated to do it wanted to keep going oh well.
Old 11-03-2008, 07:34 PM
blk99camaro's Avatar
Are you talking the hub on the disc? The part that stick out faces the rear of the car, the flat side faces the engine...maybe that will help you....
Jon
Old 11-03-2008, 10:30 PM
Ceissus's Avatar
just installed mine last week:
flywheel only goes one way.
clutch disc has an extended hub on one side. the long side goes to the BACK of the car
pressure plate only goes one way(logically)
should have mine running tomorrow if i can bleed the damned clutch.... :o)
Old 11-03-2008, 11:14 PM
N4cer's Avatar
Yeah I think he's talking clutch disc, not pressure plate.
Old 11-04-2008, 03:45 AM
INTENESS's Avatar
Thanx everyone for the help,as far as bleeding the clutch I would pick up a remote bleeder one the sponsers on the board sells them very good product saves alot of headache.
Old 11-04-2008, 01:29 PM
*98TransAm*'s Avatar
what sponsor ive been searching around and cant find one?
Old 11-04-2008, 01:43 PM
N4cer's Avatar
Tick Performance has one for like $40.
Old 11-04-2008, 11:32 PM
maybe im just blind but i couldnt find it on there website....anywhere.
Old 11-05-2008, 08:59 PM
Grifter's Avatar
It's under Corvette but fits F-Bodies also.
http://www.tick-performance.com/cata...tte/driveline/
Old 11-05-2008, 09:23 PM
thanks, do you know whats all involved in the install?
Old 11-06-2008, 05:00 PM
Grifter's Avatar
You may be able to install it without removing anything(trans and slave) but it's a tight fit. You just unscrew the bleeder and install the line into the slave. The end of the line is where you will now loosen and tighten to bleed the system.
Old 11-06-2008, 09:20 PM
alright thanks, ill be removing my trans anyway to rebuild it. to the op sorry for the thread hijack.
Old 11-07-2008, 11:24 AM
LS1TECH Sponsor
Joey@Tick's Avatar
I've added our remote bleeder to the F-Body section of our website now, as well.
