new tick mc squeaking after 400 miles
alright guys i installed a new monster stage 3 with a new tick mc and slave, everything feels great, im still getting use to the new clutch. the car has about 400 miles on the new setup, now the new tick is squeaking as i push the peddle down, i bled the slave and used 2 bottles of prestone dot 4 fluid and its still squeaking, not only that but the fluid still comes out black.
ill give tick a call monday morning and see what they say but untill then does anyone know what it could be.
You have a new MC and slave, and your fluid is BLACK Now, are you sure your MC is squeaking and you are not getting some clutch chatter during break in instead? I would think that is the case.
what sucks is that im about 2hrs away from home and the freaking peddle is starting to get mushy, if its not one thing its another.
i double checked,its the master cylinder, i got under the dash and pushed the clutch peddle down with my hand while the car was off and it still makes that squeaking noise.
Have you checked for leaks? Are you losing fluid that you know of? Did you check teh pivot point under dash, and maybe it is just the pedal *** that is making teh noise?
i looked underneath as best as i could but didnt see any type of leaks, i havent seen any fluid missing either, i disconnected the rod from the peddle and pushed the rod in and the damn thing still squeaks. another thing that is getting me confused is the peddle getting mushy
wouldnt it be to soon for a bushing to be worn out, as for squirting lubricant on the bushing ill have to wait until i get home tomorrow, the black fluid has me puzzled to
I was going to ask if you put any grease on the zerk fitting on the rod but if you are pushing it by hand then its not that making the noise.
As for the black brake fluid I cant imagine why, I installed my TMC with new fluid but still had the old slave with the little but of fluid that was in it and after about 1500 miles my fluid is still clear.
I am inclined to think you MIGHT have that, an issue with th MC. If everything is new, fluid is black though, MC squeaks (and not pedal ***.) and now pedal is getting mushy. It can still be other things of course, but does sound like a MC problem.
Yes, could be. You know, what you could do is, IF, you still have the old MC, and IF it was still good to begin with, you COULD put the old MC back on, and give it another go with old MC and new slave, and see how it flies then....
I am also noticing some squeaking coming from my Tick MC, I will be changing my fluid today, my MC has like 3,000 miles on it - still works great. I will be following this thread closely.
